• skinny b
    nube here how do folks I have an old panel truck i would like to use an old 48 star flag i have had since the 70s as a headliner and i have looked around the web and i would like to know what kind of glue should i use to stick it to the abs alot say that most of the glues might bleed through the material and ruin the flag any help from the pro would surely help thanks much
  • Eduardo sanchez
    1
    I would recommend iron on backing the flag and then using the white foam and fabric adhesive in a can. That way they add a backing to your fabric and doesn’t allow the glue to bleed through.
  • skinny b
    thanks for the reply Eduardo what kind of iron on back would u recommend trying to do this hole truck by myself since i am retired thanks again for the much needed help
  • Eduardo sanchez
    1
    I would recommend going to your local fabric/sewing store and seeing what they have in person. They should have something wide enough for your flag. If you are in the Los Angeles area I would be able to help you out.
