Trying to get vinyl to adhear to a plastic door panel. Reading through the forum, I know where I went wrong.
Been prepping the plastic parts by cleaning with laqquer thinner, sanding with 80 grit sandpaper, cleaning again with laqquer thinner, adheasion promoter, and using DAP Weldwood landau adheasive at 100% coverage on both parts.
Found out I needed to use an "felt underliner" fabric. Have been searching for the felt underliner fabric, but have come up with nothing.
What type of felt underliner fabric do I need to get and what suppliers carry it?
I acquired the underliner material from my local supplier (Fabric Supply). It is a product they called "Iron Cloth" because it cannot be torn, it needs to be cut with scissors or a knife. It bonds well to the plastic and stays in place. Vinyl can then be glued to the fabric surface without fear of it lifting or pealing.
It was a special purchase and only cost $1.50 a yard. i bought 2 rolls- 72inchs wide by 100 yards.
Thank you for the response Fred. I have called all the local upholstery suppliers in my area within a 4 hour drive and no one has anything like what you mentioned. Tried calling Fabric Supply like you mentioned, no luck unless I spoke to the wrong person.
Is there any other name that the "Iron Cloth" goes by?
You can use almost any dense fabric as an underliner material. The thing is that vinyl does not bond well to ABS plastic. The fabric does and allows you to bond vinyl to almost any surface as long as it is clean. Also remember to allow your contact cement to tack before assembling. Wet glue will not bond to anything.
