• William Duffy
    13
    I find removing cloth material that has been glued to the seat foam difficult to remove, without making a mess of the foam. An example seat would be a Cessna 152 seat. Looking for a good method to remove the old cloth. Please share your chosen technique. Thanks.
  • Andy Laird
    43
    what about an oscillating tool with a scraper blade. I use them a lot for scraping material off of panels, channeling foam with a sharpened scraper blade, or just cutting a multitude of things. I've never tried it to remove cloth from foam with it, but it's worth a try. It's a very handy tool to have around.
  • Melvin Acosta
    1
    I find steam to be helpful taking off glued covers
  • Eric Gordon
    41
    I agree steam works well. Try spraying alcohol, at times that works.
  • Jesse Durkee
    19
    On the late 90’s Chevys I just pull it off and add a layer of scrim foam to cover up the damage
  • William Duffy
    13
    Hi- thanks for the suggestions. I am going to give stream a try.
  • William Duffy
    13
    I tried steam and I worked well! Thanks all.
  • Jens Jesberg
    50
    If you don't have to reuse the cover, you can also use a warm lamp. I use the lamp most for glued leatherette covers. I heat it up to >140F°. You have to wait a while to get a deep heat. Then I carefully cut the covers in the middle with the scalpel and pull the cover outwards as if skinning. This usually works very well. Should a piece of foam get loose. Stop at this point and then start from the other side.
