Probably varies around the country we get at least $250 for an ext cab , they are somewhat of a pain, you have to pull the wiring harness off of the back of the headliner, it's glued on with hot melt glue.
There is a disconnect, way up inside the dash, I only did that ONE time!
Unplugging the harness on the Chevy pickups SUVs is a real pain, the disconnect is way down below the dash on the LH side, I did it one time, since then I just pull the harness off and either glue or tape it back on after recovering the board.
Some late model Cadillacs have the disconnect under the rear package shelf, you have to pull the rear seats trim and package shelf to access it.
For some reason a lot of folks think that headliners should be cheap,. unlike years ago most of them are not any fun to do anymore, some are very complicated, VW Jetta is one that is tough!
I had a customer come in with an 05 Toyota Avalon. It has 4 pillar air bags front and rear. I usually YouTube these cars that I'm not familiar with. No luck on this one. Any thoughts as to what I might run into with these air bags? I told customer that I would look into it before committing. Just don't want the liability of screwing something up. Man, I really don't like these newer cars today. I should stick to my old GTO style and airplanes. LOL
You shouldn’t have any issues doing that headliner as airbags are installed under the headliner. Should be able to R&R headliner w/o having to do anything involving the airbags. Really that’s typical for all newer vehicles w side curtain airbags.
We install seat air bags and new covers all the time for body shops. And on occasion when the side curtain airbags have deployed we have Installed the new headliner and those airbags, it’s not that hard to do.
The body shop has to get the SRS lights reset afterwards.
No we have done Avalon headliners and they are fairly straightforward, sometimes there are straps on the a pillars that you have to figure out how to get out,or look on YouTube to see how. And trying to recall grab handles may have push in clips not screws.
