• Hal Bast
    13
    Is there a better way to perforate vinyl for speakers than just laying it out and one punch at a time. I've done it that way, but it leaves a lot to be desired. It's so easy to get a few punches off which looks bad and sometimes a piece of backing will not cut smooth and show through. Any ideas? Thanks
  • Jesse Durkee
    19
    Look up at car audio fabrication on YouTube, the new hotness is recessed wire mesh.
  • Hal Bast
    13
    Some good ideas there, but not quite what I'm looking for. Thanks Jesse, will put this in my memory bank for later use.
  • Eric Gordon
    41
    Yes, This can be a tedious process! This is what we've always done. We create a template out of clear rear plastic window curtain with all the holes correctly marked and punched thru. Cut a piece of black waterproof panel board to the same design and size ,then split in half. Glue your finish vinyl onto the split black water proof panel board. ( The split board gives strength to the vinyl but still allows to punch thru easily) Mist glue on only the template plastic, place on top of the vinyl/panel board piece. ( The misted glue allows the template to lightly stick in place) Then mark all the holes with a china marker. Lay onto a flat cutting board and punch away.
  • Steve Ingram
    36
    I have always done it one hole at a time. With the advent of the CNC perf machine I will be sending them out from now on.
  • Hal Bast
    13
    Thanks everyone..That sounds like it will work Eric, I'm going to make the template. Making it once is a lot better than each time. Thanks again to everyone.
  • Mike Goldring
    9
    Sounds like a LOT of work, why not just buy some perforated vinyl and use it?
  • Nadeem Muaddi
    86
    I agree with @Steve Ingram. These days, you can have the vinyl professionally perforated for you.
    Hydes Leather, for instance, will do custom perforation. You can have a roll of black vinyl perforated the way you like and just store it for later use. It'll save you time when you need it later.
  • Dean McConnell
    2
    I'm guessing Hal is talking about those panels which have speaker perforations in the middle of an otherwise plain piece, such as on Mazda MX5 / Miata seats with the in-built headrest speakers, or on some door panels. In those circumstances I wouldn't think you could have a roll perforated to your needs because you'd never know how much plain vinyl you'll need surrounding the perforations for that particular job. Unless you do a lot of one particular car and can have the perforated areas spaced to suit.
  • Hal Bast
    13
    I was talking about a plain panel with a speaker in the middle...What Eric suggested will work although I haven't made the template yet. It will still be a slow job, but will look custom when done. I've seen it done, just didn't know the best way to go about it.
  • Eric Gordon
    41
    Hal. These are some of my templates I’ve used. Try printing them and glue onto a piece of vinyl or clear plastic. Hope this will help. nxamklaavstvdcch.jpeg
  • Hal Bast
    13
    I'll do it..that's exactly what I was talking about...Thanks
