How to remove/clean this mildew or mold around the window? I have always used a 10% bleach solution to clean the entire top by spraying the solution onto the top on a sunny day. Once the mildew/mold was gone, I'd rinse it with water. However, the mildew or mold around the window only will not come clean after several attempts. Is this top/window defective in some way? Any advice would be appreciated. Thank you
IMAR Strataglass protective polish Here will help get the glass clean.
RAGGTOPP Fabric & Vinyl Convertible Top Cleaner for the top itself. The sunlight should kill a lot of the mildew but cleaning it out of the cloth will be rather difficult. Using the top cleaner with a brush and rising with a hose may yield better results.
If the bleach isn’t getting into the seam, try a 1:1 white-vinegar and water mix, let it sit a few minutes, then scrub the area with a soft brush before rinsing. Make sure the window seal is fully open while you work so the solution can reach the hidden cloth, and dry the spot thoroughly afterward – the extra airflow can help keep the mold from coming back. Do you sometimes feel like a short break after cleaning, for example at [Casino ohne LUGAS](https://casinoohnelugaslimit.de/)?
