• Lindbert Guerra
    1
    Hello again my Auto trimmers; I have been usung Nylon Bonded 138 or Polyester 135 threads to stitch Steering wheels but for some home it seems to be those threads are a little too thin; when are the recommended standard size thread used for this?
    Will the 270 be too large or just right? thanks
  • Josh Dension
    4
    i usually use 92 to sew the pieces together and then i use 138 or 207 for the visible portions
  • Krunoslav Nakic
    5
    Hello guys,
    my name is Kruno and I am from Germany and work in a R&D Trimshop for a German OEM. I can tell you the most of the german OEM´s use the Serabraid line from Amann. You can have them in different thicknesses and also waxed as an option. The threads are great to work with. Cheers
  • Jens Jesberg
    50
    I agree with Kruno. The Serabraid theads works quite good for handsewing. Smaller sewingmaschines can get problems with the thickness of the thread. So maybe you have to combine the threads.
  • Naseem Muaddi
    38
    Thanks for the tip Krunoslav. I'm going to try that thread out.
