• Mike Goldring
    9
    I've been doing auto upholstery since 1983, so I generally know what to do.
    BUT we have been running into problems when recovering fairly late model Mercedes headliners.
    The material tends to delaminate just in the back area. When we pull the fabric off the foam is still very intact and dense. And it's tough to get off without damaging the fiberglass board.
    We have tried spraying the foam with alcohol, alcohol and acetone mix, Castro Super Clean, lacquer thinner, and all help to a degree. But it is still very difficult to strip the board down cleanly without damaging it.
    I really don't like to have to use two layers of material to recover a headliner.
    Who else has run into this issue? and any pointers on something that will make it easier?
  • Alexandra Novak
    Hey Mike, I ran into the same thing on a ’07 E-Class. I found that gently heating the back edge with a low-heat hair dryer helps soften the adhesive, so you can lift the foam without crushing the board. Just keep the heat low to avoid melting the vinyl.
