• William Duffy
    13
    Thoughts on cutting foam
    The marine environment is hard on upholstery. When asked to reupholster a seat, you find that not only is the outer cover in sad shape, but many times the wood back rotted. Reusing the foam is a 50/50 thing. If you are making a new plywood back and new vinyl upholstery it would be nice to use new foam.
    What do you cut foam with? A foam saw! The most popular foam saw out there is the Bosch. This is a dedicated tool made to cut foam. It has a footplate that lets you make nice square cuts. If you remove the footplate you can freehand trim with it. One really nice feature is being able to hold the guide in your hand. You can easily follow cut lines on opposite sides of the foam blank. My personal experience with this design finds the tool slow cutting and does not leave the best finish. I have used three different units, one with brand new blades, and they all work the same. On top of that they are insanely expensive!
    As hard as it maybe to believe, a turkey carving knife does a great job cutting foam. I purchased mine for 25 cents at a garage sale. It is lightweight, cuts fast and leaves a smooth finish. The only thing it is missing is a foot assembly. It is on my must have upholstery tool list.
    At the upholstery shop where I work an industrial fabric cutting machine is used to cut foam. These are usually used to cut garment parts by stacking multiple layers of fabric and cutting the pattern. It is in some ways a much larger version the Bosch foam saw. It is much more stable and cuts reasonably fast. If you are cutting large pieces of foam you should look into one.
    My favorite tool for cutting foam is the bandsaw. If you are cutting geometric shapes this is the tool! It is fast cutting and leaves a nice finish. If you need to cut an angle you just tilt the table. Using a fence, it is easy to cut parallel lines. Finally, this may be the best, you can glue foam to a plywood/plastic base and easily cut the foam leaving an overhang. Here is how you do it. Make a temporary fence out of wood the same or less then the thickness of your backing material. Cut a notch in it so the fence can extend past the blade. The base runs along the fence let’s say ¼”, for example, from the blade. The blade cuts the foam a perfect ¼” from the base material. I will post a picture to make it clearer.
    It goes without saying that if you are freehand cutting thin foam just use a scissor. It would be great if others would share their experience.
  • Michael cullen
    6
    I also use a 3" air buff for shaping.
    But you can't go past the electric carving knife.
  • Joseph Bennell
    5
    Nice write up, my personal preference is the electric carving knife i cant see me paying out for a Bosch foam saw any time soon.
    Nice write!
    Buy a Bosch 1575A Foam Rubber Cutter where you can. Earlier this year a rep told us the tool has been discontinued...
  • William Duffy
    13
    I reasonably purchased a “pre owned” Bosch foam saw for $45. That was a price I could live with. It seems to me that the motor unit should not be any more expensive then a quality jig saw. If you have to have a brand new one, consew seems to have purchased the product.
    The average price is around $450. Pure principle alone prevented me from buying brand new.
    Good to know! @Naseem Muaddi check this out^^
    Thanks!
  • Naseem Muaddi
    38
    I have an older model Bosch saw that I bought used for $20. I use that for most of my work but when I want nice clean cuts I use my bandsaw. I also use non-serrated knives for quick simple cuts.
    I like @William Duffy idea for cutting foam with an overhang. Good idea. I'll try that
  • Michael cullen
    6
    We wish a foam cutter min$120+ tp $800.
    The joys of down under
  • Elizabeth Contreras
    9
    I use a bad saw and a carving knife. I have used sailrites foam cutting tool but I'm not that great at using those. The price on them is not too bad.
  • Jens Jesberg
    50
    A bandsaw is great if you have enough space in your workshop. I have 2 Bosch GSG300. One with a 13" blade and on with 31" blade for big jobs. I always have an eye on the german amazon warehouse deals. The last one i get under 300€.
    9
    I like the bandsaws...I have a small small shop but I'm able to wheel it out of the way. I think mine is only 7". I want to get a bigger one but I need to be able to put wheels on it to move it.
  • Naseem Muaddi
    38
    Where did you find a 31" blade? I'd love to get a blade that long for my machine
  • Roy Keith Powell
    6
    I have replaced the trusty turkey carver with fish filet knives. The blades come in an assortment of sizes and widths. I like the thinner blades with small tipped ends, They are a bit more money than the cheap $20 hardware store models but they seem to last longer.
  • Jens Jesberg
    50
    Its a regular product (no bosch OEM - but also high quality) i can get from some of my supplier. I bought it years ago for cut off the foam of bigger motorcycle seats. But last year i get sick of changeing the blades so i bought the second gsg300.
    I will make some pic and check out the price for it tomorrow.
  • Jens Jesberg
    50
    I am a liar or rather i dont know my tools exactly :-! I just got the 24" blade. :D But a 31" is available.
    I got 2 suppliers Diekraefe and Binder. The prices are nearly the same. If somebody is interested in an order I can manage a order if there are problems with language or international shipping. bcod5kapq7uuones.jpg
  • Krunoslav Nakic
    5
    Hello together,
    there is also a nice cutting/attachment table to cut angles to foam. The table is made for the Bosch GSG300 foam cutter which most of us use. I saw the table on a presentation of the company ED Ernst Diekgraefe GmbH & Co.
    Ebay link is http://www.ebay.de/itm/Dammstoffzuschneidetisch-fur-Bosch-Schaumstoffsage-GSG-300-Elektro-Druckluft-/112595184078?hash=item1a373229ce:g:K~MAAOSwmmxW1wav
    It is a really nice guide to cut foam to an angle.
  • Andy Laird
    43
    I used an electric knife for years and finally broke down and bought the Bosch. I should have done that form the beginning, its my go to for foam. I do have an electric straight knife like the picture in the first post but I almost never use it (for foam anyway). Its a large powerful machine but a bit awkward to use, especially with a chain-mail glove. I do use the blades however, they work awesome for smaller freehand work. I'll add a pic. its basically an 8" razor blade. If interested you can buy them here http://www.allbrands.com/categories/1915, or just do a search for 8" straight knife replacement blades.n21i3tusbpxaeppf.jpg
    I do like using the band saw, but I would love to have the pin wire saw. Though I don't have the room or the $$ for that. I cant seem to find a price on it now but I think it was around $25K. I do plan on building my own some day. A replacement blade is $155 from Skandia. akgsj6sqlzu57930.jpg
    Here is a video from Skandia showing some of the capabilities. With the wire you can cut in any direction. The table tilts making angles easy. I used this saw while working for an aviation company. We also had a vacuum board to hold foam in place while cutting. It is an awesome setup. https://www.youtube.com/watch?v=1p0J2FqoebI
  • Chad Mergelkamp
    I agree Andy, I too work for an aviation company and have used a Skandia pin saw for 12 years now. They are awesome tools for cutting profiles in large foam cushions. To build one really wouldn't be that big of a task if you are handy with a welder. They are basically 4 pulleys that have a groove in them for the wire and an electric motor to turn the pulleys. Aside from a framework and table top, that's really all there is to them.
  • Al Decker
    22
    I also worked on aircraft. (Biz Jets) & I loved using the pin saw. But the price is really hard to justify for a one man, 2 project-at-a-time shop.
    Our wood shop guys made us a vacuum box to use with the saw. It held the foam upright via the vacuum, to do long angled/tapered cuts
    As far as building one, I've considered a bandsaw with modified pulleys so as to be able utilize the pin wire that the Scandia machine uses.
  • Geoff Horsfall
    8
    [img][/img]
    After hearing about the Bosch being discontinued , I've been checking my suppliers. All of them said no stock but just last week I was ordering some stuff from a supplier I don't use that often and asked if they had one and they said yup , just one. I'll take it I said .
    700 bucks later it's here, blades and guide coming from another place. I've had a Bosch for 15yrs ,so this one will take me through till retirement lol.
    Thanks for the tip on the bosch being discontinued !
  • Darren Rawlings
    6
    I've used carving knifes and then got the Bosch ...pricey but didn't look back, just quick and easy. Shame if it's being discontinued ...maybe someone else will produce something similar but a little less expensive for people.
  • Geoff Horsfall
    8
    The supplier i bought from said they used to sell a foam saw called the EZ cutter which was way cheaper but it was not a very good product . I also phoned Bosch and anyone else that sold Bosch about the GSG 300 but no one knew anything about it.
  • Andy Laird
    43
    ditto the ez cutter. I had one and it only lasted 1.5 years
    I just found this one from consew. I don't know anything about it but it may be worth looking into
    foam saw
  • Geoff Horsfall
    8
    I saw that one too, apparently the consew name is being thrown around a lot on the Chinese cloned stuff.
    It's not the Japanese Consew that made awesome sewing machines but you never know , it might be ok.
  • Jens Jesberg
    50
    Wow! 700$ is not really cheap. The regular price on german amazon is actually 500$ (without sword). And a few days ago i saw a warehousedeal for 380$. I can keep an eye on this if someone interested.
  • Geoff Horsfall
    8
    700 Canadian that is.
  • Jens Jesberg
    50
    Oh sry! I missed that information. Thats also a common price over here. ;)
  • Geoff Horsfall
    8
    Ya, still expensive but nothing else works as well. Totally worth the money in my opinion.
