• anthony simpson
    3
    How does everyone create new listing designs in a preexisting seat foam to create new patterns? I 'm trying to learn different technics to creat my own unique designs in seats without changing the existing foam but haven't figured out the best method in doing so. Wanting to know how your attaching it to the foam. Curious to hear everyone's technics of accomplishing this
  • Eddie Rosenkoetter
    4
    I’d like to know this as well if anyone is kind enough to share.
  • Cody Lunning
    39
    Make that a third person interested. Maybe this would be a good article for the home page @Nadeem Muaddi
  • Adam Gabriel
    16
    depends on your application and I can only speak on behalf of the ones i know..
    1-Wood base- cut foam and pull tether down to staple
    2-obviously you could liquid listing (glue it down inside or to the foam)
    3- Or you can sew the listings in the seats, use a long needle and sink it down through the foam and tie on the backside. Channeling the foam out will make the listing pull inside more.
  • Peter Pittel
    11
    Plastic zip ties,can be pulled down through slits in the foam. Build up or remove foam to achieve the desired shape.
  • Jeremy caron
    8
    I like to channel the foam with a trim router and a 1/2ā€ wide cutting bit, then use Velcro like many modern seats
